Kabel Deutschland Starts DVB-C2 Field Trial
05 Jul 2013 00:03 #49
Réponse de BAISIN sur le sujet Kabel Deutschland Starts DVB-C2 Field Trial
New BRAVIA SONY 4 K may receive DVB-C2 channels, on German CATV (select " Deutschland" before automatic scan)
Le nouveau tv SONY Bravia 4K est déjà prêt pour le DVB-C2 (cliquer "deutschland" avant la recherche automatique).
Naturellement, son triple tuner intégré( DVB-T2/DVB-C2/DVB-S2), est compatible avec les téléréseaux Suisses, avec une CI+ pour une éventuelle DIGICARD, ainsi que pour le CAM de FRANSAT, de SAT ACCESS HD, et BIS TV .
28 Jui 2013 20:57 #7
par redge
Kabel Deutschland Starts DVB-C2 Field Trial a été créé par redge
Kabel Deutschland Starts DVB-C2 Field Trial In Berlin, Hamburg & Munich
Kabel Deutschland began transmission of the new DVB-C2 standard on cable channel D794 (794 MHz center frequency) at ANGA. This formed part of the extended DVB-C2 field trial on its CATV networks in Berlin, Hamburg and Munich. The field trial will become a regular service as soon as compliant receivers are widely available.
"The essential advantages of DVB-C2 are the excellent spectrum efficiency and the flexibility to adapt the parameters to the characteristics of the individual network or application", said Lorenz Glatz, Chief Technology Officer of Kabel Deutschland. The key building blocks of DVB-C2 are the new OFDM modulation scheme and the powerful LDPC error protection system, which will also be used in the DOCSIS 3.1 standard. DVB-C2 will allow an increase in the maximum downstream capacity of an 862 MHz cable network from its present 5 Gbit/s to up to 8 Gbit/s. "The introduction of this new standard will further improve the competitiveness of our already very powerful cable infrastructure and allow for the extending of the service offerings significantly. Our customers can look forward to a new range of products and services", Glatz added.
This is the first time a DVB-C2 1024-QAM modulation scheme, at 3/4 FEC-rate, has been deployed in a CATV network, improving spectrum efficiency by 46 percent over DVB-C at the same signal level. "We now hope that the CE industry will equip their digital TV receivers with combined DVB-C2/DVB-C front-ends, enabling us to extend our DVB-C2 offering", said Frank Hellemink, Vice President Network Engineering at Kabel Deutschland.
source:
DVB Scene eNews Issue 23
source:
Temps de génération de la page : 0.147 secondes
